February 12, 2019 at 9:18 am
Risto86
SubscriberI'm attempting to make my way through some of the learning hub courses as I await my university to license our sponsored software package, using the free student edition in the meantime.
I've gone through this exercise numerous times, starting from scratch twice, and I continue to get the error notices "Non-zero exit code 2" and on the CFX solver outfile, "Solver exited with return code 1".
My understanding is that the student version has a node/element limit of 152k, which was never approached but I still received the error. I went back and applied mesh sizing limits to reduce the mesh to below 32k and I still receive the error.
Is the issue a misapplication somewhere in the meshing or setup process? An issue with my computer, or simply that I'll need to have the licensed academic version to run the solver on this problem?
Attached file note: v0 is before mesh adjustment, v1 is after using sizing to reduce element count.
Will update if I find a solution before someone responds.
Thanks!
February 12, 2019 at 9:45 am
Forum ModeratorYou've got a 512k cell count limit, so should be fine with the tutorials. Are there any warnings/messages before the exit code? Those tend to be more useful. Also check disc space both in the working directory but also scratch (set in Workbench -> Tools).Â
February 12, 2019 at 9:58 am
DrAmine
Ansys EmployeeAre you seeing any license error messages in the CFX out file?
February 12, 2019 at 11:15 am
Risto86
SubscriberI recorded my desktop as I ran the solver so you can see what I see. I've also attached the CFX solver out file as copied into notepad, which does show a warning on the top which I don't understand. I monitored my computer cpu usage and memory during a subsequent run, and it didn't get anywhere near maxed out. (edit with attached mp4 pending)
Within (tell me if this is the right place to look to check disc space) Workbench->Tools->Options->Mechanical ADPL->Default Memory: 1024mb; Workspace Memory: 1048mb.
I haven't seen any notice of license errors in the outfile, unless I somehow overlooked it multiple times
February 12, 2019 at 11:51 am
Forum ModeratorFor the disc space just use the File Manager/Explorer and check for free space. As staff we can't open attachments so can't review the out file.Â
February 12, 2019 at 12:04 pm
Risto86
SubscriberThat's unfortunate, I'll take it the video will be a waste to upload... I have 676 GB of free space on my computer
The warning at the top of the file is "Warning! Revision is over 16 characters long 39"
Then at the bottom I see: "An error has occurred in cfx5solve:Â The ANSYS CFX solver exited with return code 1. No results file has been created."
Full out file as below:
Warning!
 This run of the CFX Welcome to ANSYS Student Discovery Live Solver
 started at 02:55:06 on 12 Feb 2019 by user risto on DESKTOP-17EOLLP
 (intel_xeon64.sse2_winnt) using the command:
 "C:Program FilesANSYS IncANSYS Studentv192CFXbinperllibcfx5solve.pl"
  -batch -ccl runInput.ccl -fullname CFX_003
 Point Releases and Patches installed:
 Academic Student Release 19.2
 FENSAP-ICE Release 19.2
 AIM Academic Student Release 19.2
 AIM Release 19.2
 Discovery Release
 Setting up CFX Solver run ...
CFX Command Language for Run
 LIBRARY:
  MATERIAL: Water
   Material Description = Water (liquid)
   Material Group = Water Data, Constant Property Liquids
   Option = Pure Substance
   Thermodynamic State = Liquid
   PROPERTIES:
    Option = General Material
    EQUATION OF STATE:
     Density = 997.0 [kg m^-3]
     Molar Mass = 18.02 [kg kmol^-1]
     Option = Value
    END
    SPECIFIC HEAT CAPACITY:
     Option = Value
     Specific Heat Capacity = 4181.7 [J kg^-1 K^-1]
     Specific Heat Type = Constant Pressure
    END
    REFERENCE STATE:
     Option = Specified Point
     Reference Pressure = 1 [atm]
     Reference Specific Enthalpy = 0.0 [J/kg]
     Reference Specific Entropy = 0.0 [J/kg/K]
     Reference Temperature = 25 [C]
    END
    DYNAMIC VISCOSITY:
     Dynamic Viscosity = 8.899E-4 [kg m^-1 s^-1]
     Option = Value
    END
    THERMAL CONDUCTIVITY:
     Option = Value
     Thermal Conductivity = 0.6069 [W m^-1 K^-1]
    END
    ABSORPTION COEFFICIENT:
     Absorption Coefficient = 1.0 [m^-1]
     Option = Value
    END
    SCATTERING COEFFICIENT:
     Option = Value
     Scattering Coefficient = 0.0 [m^-1]
    END
    REFRACTIVE INDEX:
     Option = Value
     Refractive Index = 1.0 [m m^-1]
    END
    THERMAL EXPANSIVITY:
     Option = Value
     Thermal Expansivity = 2.57E-04 [K^-1]
    END
   END
  END
 END
 FLOW: Flow Analysis 1
  SOLUTION UNITS:
   Angle Units = [rad]
   Length Units = [m]
   Mass Units = [kg]
   Solid Angle Units = [sr]
   Temperature Units = [K]
   Time Units =
  END
  ANALYSIS TYPE:
   Option = Steady State
   EXTERNAL SOLVER COUPLING:
    Option = None
   END
  END
  DOMAIN: junction
   Coord Frame = Coord 0
   Domain Type = Fluid
   Location = Fluid Domain
   BOUNDARY: inlety
    Boundary Type = INLET
    Location = inlet y
    BOUNDARY CONDITIONS:
     FLOW REGIME:
      Option = Subsonic
     END
     HEAT TRANSFER:
      Option = Static Temperature
      Static Temperature = 10 [C]
     END
     MASS AND MOMENTUM:
      Normal Speed = 5 [m s^-1]
      Option = Normal Speed
     END
     TURBULENCE:
      Option = Medium Intensity and Eddy Viscosity Ratio
     END
    END
   END
   BOUNDARY: inletz
    Location = inlet z
     FLOW REGIME:
      Option = Subsonic
     END
     HEAT TRANSFER:
      Static Temperature = 90 [C]
     END
     MASS AND MOMENTUM:
      Normal Speed = 3 [m s^-1]
     END
     TURBULENCE:
     END
    END
   END
   BOUNDARY: outlet
    Boundary Type = OUTLET
    Location = outlet
     FLOW REGIME:
      Option = Subsonic
     END
     MASS AND MOMENTUM:
      Option = Average Static Pressure
      Pressure Profile Blend = 0.05
      Relative Pressure = 0 [Pa]
     END
     PRESSURE AVERAGING:
      Option = Average Over Whole Outlet
     END
    END
   END
   BOUNDARY: wall
    Boundary Type = WALL
    Location = F29.40,F30.40,F31.40,F32.40,F33.40
     HEAT TRANSFER:
      Option = Adiabatic
     END
     MASS AND MOMENTUM:
      Option = No Slip Wall
     END
     WALL ROUGHNESS:
      Option = Smooth Wall
     END
    END
   END
   DOMAIN MODELS:
    BUOYANCY MODEL:
     Option = Non Buoyant
    END
    DOMAIN MOTION:
     Option = Stationary
    END
    MESH DEFORMATION:
     Option = None
    END
    REFERENCE PRESSURE:
    END
   END
   FLUID DEFINITION: Fluid 1
    Material = Water
    Option = Material Library
    MORPHOLOGY:
     Option = Continuous Fluid
    END
   END
   FLUID MODELS:
    COMBUSTION MODEL:
     Option = None
    END
    HEAT TRANSFER MODEL:
     Option = Thermal Energy
    END
    THERMAL RADIATION MODEL:
     Option = None
    END
    TURBULENCE MODEL:
     Option = k epsilon
    END
    TURBULENT WALL FUNCTIONS:
     Option = Scalable
    END
   END
  END
  OUTPUT CONTROL:
   MONITOR OBJECTS:
    MONITOR BALANCES:
     Option = Full
    END
    MONITOR FORCES:
     Option = Full
    END
    MONITOR PARTICLES:
     Option = Full
    END
    MONITOR POINT: p inlety
     Expression Value = areaAve(Pressure )@inlety
     Option = Expression
    END
    MONITOR POINT: p inletz
     Expression Value = areaAve(Pressure )@inletz
     Option = Expression
    END
    MONITOR RESIDUALS:
     Option = Full
    END
    MONITOR TOTALS:
     Option = Full
    END
   END
   RESULTS:
    File Compression Level = Default
    Option = Standard
   END
  END
  SOLVER CONTROL:
   Turbulence Numerics = First Order
   ADVECTION SCHEME:
    Option = High Resolution
   END
   CONVERGENCE CONTROL:
    Length Scale Option = Conservative
    Maximum Number of Iterations = 100
    Minimum Number of Iterations = 1
    Timescale Control = Auto Timescale
    Timescale Factor = 1.0
   END
   CONVERGENCE CRITERIA:
    Residual Target = 1.E-4
    Residual Type = RMS
   END
   DYNAMIC MODEL CONTROL:
    Global Dynamic Model Control = On
   END
  END
 END
 COMMAND FILE:
  Version = 19.2
  Results Version = 19.2
 END
 SIMULATION CONTROL:
  EXECUTION CONTROL:
   EXECUTABLE SELECTION:
    Double Precision = No
    Large Problem = No
   END
   INTERPOLATOR STEP CONTROL:
    Runtime Priority = Standard
    MEMORY CONTROL:
     Memory Allocation Factor = 1.0
    END
   END
   PARALLEL HOST LIBRARY:
    HOST DEFINITION: desktop17eollp
     Remote Host Name = DESKTOP-17EOLLP
     Host Architecture String = winnt-amd64
     Installation Root = C:Program FilesANSYS IncANSYS Studentv%vCFX
    END
   END
   PARTITIONER STEP CONTROL:
    Multidomain Option = Automatic
    MEMORY CONTROL:
    END
    PARTITION SMOOTHING:
     Maximum Partition Smoothing Sweeps = 100
     Option = Smooth
    END
    PARTITIONING TYPE:
     MeTiS Type = k-way
     Option = MeTiS
     Partition Size Rule = Automatic
    END
   END
   RUN DEFINITION:
    Run Mode = Full
    Solver Input File = CFX.def
    Solver Results File =
     C
Users/risto/Desktop/WS01-Mixing-Tee_pending/dp0_CFX_Solution/CFX_0
     03.res
   END
   SOLVER STEP CONTROL:
    MEMORY CONTROL:
    END
    PARALLEL ENVIRONMENT:
     Number of Processes = 1
     Start Method = Serial
    END
   END
  END
 END
Solver
ANSYS(R) CFX(R) Solver
End of solution stage.
 For CFX runs launched from Workbench, the final locations of directories
and files generated may differ from those shown.
This run of the ANSYS CFX Solver has finished.
February 12, 2019 at 1:11 pm
DrAmine
Ansys EmployeeLooks consistent: are there any other error messages printed in the CFX console? Can you try running the definition file in CFX Standalone? Can you attached the definition file here?
February 12, 2019 at 4:09 pm
Risto86
SubscriberI'm sorry, can you explain what you're asking for, or point me to an explanation of how to do it?
February 12, 2019 at 6:04 pm
DrAmine
Ansys EmployeeYou have a definition file created in the workbench directory (name*.def). Now Start CFX Solver out of the Workbench: Start Programs, CFX, then CFX Solver from the CFX Launcher Panel, define Run, give the path to the definition file and start.
February 15, 2019 at 3:46 am
Risto86
SubscriberI apologize, it took me a couple of days to get back to this.
I tried your suggestion, and the result is exactly the same in the Solver Manager, but I do have a shell window with this additional output:
Warning!
0Â Â INFOÂ Â Â Â Â Â Â Â Demo license file C:Program FilesANSYS IncANSYS StudentShared FilesLicensingstudent.lic exists.
Warning!
Unable to assign product revision id.
Use of uninitialized value $data_items{"Application.Buildinfo"} in sprintf at C:Program FilesANSYS IncANSYS Studentv192CFXbin/perllib/CFX5/Simulation/Configuration/APIP.pm line 119.
Use of uninitialized value $data_items{"Mesh.Elements"} in sprintf at C:Program FilesANSYS IncANSYS Studentv192CFXbin/perllib/CFX5/Simulation/Configuration/APIP.pm line 119.
Use of uninitialized value $data_items{"Mesh.Faces"} in sprintf at C:Program FilesANSYS IncANSYS Studentv192CFXbin/perllib/CFX5/Simulation/Configuration/APIP.pm line 119.
Use of uninitialized value $data_items{"Mesh.Nodes"} in sprintf at C:Program FilesANSYS IncANSYS Studentv192CFXbin/perllib/CFX5/Simulation/Configuration/APIP.pm line 119.
Use of uninitialized value $data_items{"Mesh.Zones"} in sprintf at C:Program FilesANSYS IncANSYS Studentv192CFXbin/perllib/CFX5/Simulation/Configuration/APIP.pm line 119.
Use of uninitialized value $data_items{"Session.TotalCpuTime"} in sprintf at C:Program FilesANSYS IncANSYS Studentv192CFXbin/perllib/CFX5/Simulation/Configuration/APIP.pm line 119.
February 15, 2019 at 7:05 am
DrAmine
Ansys EmployeeCan you please for debugging purposes create a simple pipe with velocity inlet, wall and pressure outlet, carry out that steady simulation and check if it works. Thanks
February 15, 2019 at 9:58 am
Risto86
SubscriberIt seems that there was an issue with the geometry. I created my own version of the tee in SpaceClaim and the simulation ran perfectly!
February 15, 2019 at 10:32 am
DrAmine
Ansys EmployeeNice. Please mark this as resolved.
- The topic ‘Issue with CFX solver in Learning Hub’s WS01-Mixing-Tee exercise’ is closed to new replies.
3597
1208
1092
1068
952
