September 27, 2023 at 2:21 pm
Lukáš Trizuljak
SubscriberHello,
Is anyone able to help me with this error message? I try to load a case into Fluent from a class and this error keeps popping up:Â
Reading mesh ...
10000 cells, 1 cell zone ...
10000 quadrilateral cells, zone id: 2
20425 faces, 5 face zones ...
19575 2D interior faces, zone id: 3
400 2D symmetry faces, zone id: 4
25 2D velocity-inlet faces, zone id: 5
25 2D pressure-outlet faces, zone id: 6
400 2D wall faces, zone id: 7
10426 nodes, 1 node zone ...
Done.
Error: EOF in string read
Error Object: ()
Error: api-get-var: the object is not active
Error Object: setup/general/solver/time
Real overflow
Real underflow
Real overflow
Real underflow
I'd be grateful for any help.
Thanks!
September 28, 2023 at 10:10 am
Forum ModeratorWhich version of Fluent were you using in class, and which version are you reading it into? The mesh may be OK, but the api-get-var suggests there's something missing that's model related.Â
- The topic ‘Issue loading case files into Fluent’ is closed to new replies.
4597
1495
1386
1209
