Ansys Products
Ansys Products
Issue Inserting Mechanical B.C./Loads in Thermo-Structural Analysis
    • jmcclos8
      I am relatively new to Ansys, and I apologize this wasn't the most appropriate place to ask this question. I am performing a thermo-structural analysis in Ansys Mechanical. I successfully ran the heat transfer analysis and imported the results to the structural analysis. However, when I attempted to insert boundary conditions or loads no detail dialogue box appears, and I am unable to insert them in the Structural portion of the analysis. If anyone knowns how to fix this issue, any help would be much appreciated.
    • Chandra Sekaran
      Perhaps some pictures of the project page workflow and also pictures showing details dialog not showing may help.
      • jmcclos8
        Here is an Image of the workflow for the simulation. To further clarify, for example, when I click to insert a Fixed Support, nothing happens. The details dialouge box remains as shown in the screenshot and I am unable to select anything regarding the Fixed Support.
    • Chandra Sekaran
      So when you click on 'Fixed' like shown below nothing happens?
      • jmcclos8
        Yes this is Correct
    • mjmiddle
      What happens when you right click on the Analysis branch and go to the Insert menu?
      There are 3 cases I can think of where you can't insert Outline objects:
      1. Mechanical was opened in read-only mode or left open for a long time and lost the license. It will say read-only at the bottom of Mechanical.
      2. A solution is running. You only get a couple options in a right click menu then, such as "Open Solver Files Directory."
      3. Mechanical database is corrupted. You can try to recover by finding the *.mechdb files in the project. Copy outside the project and rename extension to .mechdat. Then in a new, empty workbench project, press the Import button for each mechdat.
      You'll need to set the file filter to "Importable Mechanical File."
  • The topic ‘Issue Inserting Mechanical B.C./Loads in Thermo-Structural Analysis’ is closed to new replies.
