May 15, 2024 at 2:48 pm
nicolo.cappello
SubscriberDear All,
I need to get an info which is somehow crucial: I'm doing time-dependent simulation of an axisymmatric system using Fluent 2023R2, and I need to monitor the volume flow rate through the cross-section in the middle of a duct. Such cross-section is perpendicular to the axial direction, so in practice it is a radial line. I've defined a new Line-surface (by means of the TUI, that is surface/line-surface ...) and defined a report definition (Surface Report -> Volume Flow Rate) to get the volumetric flow rate through that surface.
The problem is that the signal I get is the opposite of the one I expect from physics. So I have to conclude that Fluent is considering as normal to the surface the opposite of the one pointing in the positive axial direction. Â
My question is: how does Fluent define the unit normals to surfaces internal to the domain which have been created from the TUI?
Thanks in advance for the precious help.
Nicolò
May 16, 2024 at 1:00 pm
Forum ModeratorAre you reporting on a line or an interior surface? Please can you post a screen grab of the report definition?
May 22, 2024 at 8:28 am
nicolo.cappello
SubscriberHi Rob, I'm sorry for bothering. Have you tried take a look at my question?
Thanks a lot.
Nicolò
May 16, 2024 at 1:47 pm
nicolo.cappello
Subscriber-
May 17, 2024 at 8:46 am
nicolo.cappello
SubscriberJust to be clear, when I run the simulation I get a volume flow rate which is positive in the convergent direction of the duct, which is wrong I think. What am I missing?
May 22, 2024 at 12:44 pm
Forum ModeratorSorry, we had a message issue & I was then off for a few days.Â
There isn't a normal associated with those surface types so I'd tend to use mass averged velocity (vector) to get mass flow data.Â
May 23, 2024 at 8:43 am
nicolo.cappello
SubscriberDear Rob, no problem, thank you for your support.
So if I've understood it correctly you suggest defining a custom vector corresponding to the velocity vector and then use Surface Report -> Custom Vector Flux ?
Am I misunderstanding your advice?
Thank you!
May 30, 2024 at 4:03 pm
Forum ModeratorNo, I'd use the x, y or z velocity depending on what's normal to the plane.Â
July 11, 2024 at 9:19 am
nicolo.cappello
SubscriberAlright, I've got it!Â
Thanks a lot for your precious advices!
- The topic ‘Issue in Computing Fluxes through New Created Surfaces — Fluent 2023R2’ is closed to new replies.
5979
1307
