May 7, 2024 at 3:24 am
Stemphanie_anansu
I want to output the ISAT table after performing a 24-core parallel EDC calculation,but after clicking file→write→ISAT table file, no result is output,
and then I try to use the TUI command, still no result: /file/write-isat-table
Trying to use the filename XXX-0.isat to output also did not work.
Why is this? What do I need to set in order to output? -
May 10, 2024 at 7:22 am
Essence
Ansys EmployeeHello,
Could you share the screenshot of the ISAT panel in Species model?
- The topic ‘ISAT table cannot be output’ is closed to new replies.
