TAGGED: additive-manufacturing, help, mechanical, simulation
October 19, 2020 at 11:58 amGmadd SubscriberHello,nfor a course project, I'm trying to simulate a direct energy depostition (DED) additive manufacturing process with Ansys 2019 R3 Student.nAs of now, I'm using a Transient Thermal with module an APDL script that generates a moving heat source along a path, a modified version of this Moving Heat Source ACT, paired with a Static Structural.n I'm working on creating the elements progressively while the heat source pass on it, in order to see the stresses/deformations in the piece and the substrate.nThe piece is for now a simple single track, 1mm wide and 0.125mm tall, but the idea is to generalize the script for an arbitrary mesh.nnIs this the correct way of doing it or there are other better alteratives?nAny input is appreciated, thank you.n I'm working on creating the elements progressively while the heat source pass on it, in order to see the stresses/deformations in the piece and the substrate.nThe piece is for now a simple single track, 1mm wide and 0.125mm tall, but the idea is to generalize the script for an arbitrary mesh.nnIs this the correct way of doing it or there are other better alteratives?nAny input is appreciated, thank you.n
October 29, 2020 at 3:36 pmKarthik Remella AdministratorHello, nPlease refrain from creating duplicate posts so we can streamline support. We are answering your question here. Please post your responses here.nHello,for a course project, I'm trying to simulate a direct energy depostition (DED) additive manufacturing process with Ansys 2019 R3 Student.As of now, I'm using a Transient Thermal with module an APDL script that generates a moving heat source along a path, a modified version of this Moving Heat Source ACT, paired with a Static Structural.https://us.v-cdn.net/6032193/uploads/7KKXKFCGFCK5/immagine.pngI'm working on creating the elements progressively while the heat source pass on it, in order to see the stresses/deformations in the piece and the substrate.The "piece" is for now a simple single track, 1mm wide and 0.125mm tall, but the idea is to generalize the script for an arbitrary mesh.Is this the correct way of doing it or there are other better alteratives?Any input is appreciated, thank you./forum/discussion/21387/additive-manufacturing-process-ded-simulation-help I'm closing this post.nThank you.nKarthikn
- The topic ‘Is this how to set-up an additive DED process simulation?’ is closed to new replies.
- APDL, memory, solid
- Meaning of the error
- Contact stiffness too big
                        4167
                        1487
                        1363
                        1189
 You are navigating away from the AIS Discovery experience
