December 6, 2023 at 9:35 am
Sangmyeong Yu
I conducted a simulation and observed unnatural spectra at certain points. Could this phenomenon be attributed to nonlinear optics, or should it be considered a simulation error? There were no error messages after the simulation concluded. I specified the mesh, and the boundary conditions (BC) for the xy axis are periodic. The source used is a plane wave. -
December 6, 2023 at 1:07 pm
Afroditi Petropoulou
Ansys EmployeeDear Sangmyeong,
What are the materials that you are using for the two objects and what are their dimensions (of the rectangular, cylinder and FDTD region)?
As I can see you run a sweep over the period, is that correct? Is it for both x and y axis span?
Did you check the material fitting in the material explorer to see if it is ok for the whole bandwidth (300nm-1000nm)?
Thank you in advance.
Best Regards,
Afroditi
December 7, 2023 at 5:05 am
Sangmyeong Yu
SubscriberHere, my sweep setting and material fittings(300nm~1000nm and 380 nm 780 nm Ag), and I used Ag(cylinder), Si3N4(cylinder), SiO2(rectangular).
Si3N4, SiO2 material fitting is perfect but Ag is not correct.
I believe I have done my best in material fitting. Also, I used the Ag (Silver) provided in FDTD.
December 8, 2023 at 9:43 am
The first fitting (first image that you shared) looks fine.
I have a question though for the sweeps. Is the second sweep inside the first one?
If yes, I see that the radius is up to 0.13um will the period (y and x FDTD span) is down to 0.2um. Is this intentional? Because for 0.2um span and 0.13um radius the cylinder will be larger than the simulation area in x and y axis. This might give weird results. Since you have periodic boundary conditions, in this case the cylinders will overlap.
Best Regards,
Afroditi
- The topic ‘Is there the error in this simulation?’ is closed to new replies.
5664
1890
1419
1304
