TAGGED: b, bolt-modelling, bolted-connection, fastener, static-structural
October 27, 2021 at 6:39 pm
sid10mahesh
SubscriberI understand that we won't directly get the stress values on a bolt modelled as a beam element. But I have noticed that if we probe the beam location we get maximum values of forces over time on the beam. My question is from that value of forces is there any way we can hand calculate the approximate stress on the bolt? Can any one tell me the formulation if possible ?
Can some one help me with this regard? Any help in this will be greatly appreciated. Thanks in advance!
October 27, 2021 at 11:01 pmpeteroznewman
SubscriberSee if you find the equations on this page helpful: https://www.engineeringtoolbox.com/bolt-stretching-d_1164.html
October 28, 2021 at 4:11 amsid10mahesh
SubscriberThe equations in the link that you shared consists of only the effect due to axial load I guess. But I do have an effect on my bolt due to combined loading.
Is it equivalent to applying the prescribed loads as given by the beam probe individually on the bolt and then determining the stresses ? Is that a valid method ? Or is there any simpler method ?
October 28, 2021 at 1:27 pmpeteroznewman
SubscriberRead the discussion in the link below. Pay no attention to my post marked "Best Answer". It is not the best answer. You will find a long reply that describes the workflow to design a bolted joint.
Here is another useful discussion with videos of how to create a bolted joint simulation.
Viewing 3 reply threads- The topic ‘Is there any way to calculate stress on a bolt modelled as beam element in ANSYS?’ is closed to new replies.
4999
1676
1387
1248
