Is there any way not to use the AMG solver?
    • ibopaul
      Hello! I'm trying to compare the performance of AMG solver.nI found turn off the AMG solver by setting Max Coarse Levels to '0'.nHowever, after I turn of the AMG solver, which linear equation solver I use?nstill, after i turn off the AMG, there are pre relaxation and post relaxation blanks and inner cycle blanks. Also there only two smoother types (ILU, Symmetry Gauss-Seidel). nIf I turn off the AMG, AMG-related blanks (pre-relaxation, post relaxation & inner cycle) are just ignored?nIs there any way to use one Gauss-Seidel iteration method on flow solver? (to compare AMG acceleration performance)nMy simulation is steady & density based.nnThank you.n
    • YasserSelima
      From the theory guidennn
    • Amine Ben Hadj Ali
      Why?n
    • ibopaul
      I wanted to know the speed difference as to whether or not to use AMG.nIs it impossible to compare the calculation speed?nThank you.n
      With AMG you will always have quicker runs. It is practically impossible to have reasonable run times without using Multigrid Methods. n
Viewing 4 reply threads
  • The topic ‘Is there any way not to use the AMG solver?’ is closed to new replies.
