Electronics
Electronics
Is there a way to display a force vector in Maxwell?
    • hector
      I modeled some 3D magnets and ran an analysis after assigning a force parameter to one of them. The analysis result is a resultant force vector with x,y, and z components. Is there anyway to display this vector to help visualize it? Thanks
    • Timos
      Hello, you can visualize the vector by selecting a surface of the magnet that the force is applied and then right click> Fields> Other> Surface_Force_Density. Moreover, you can visualize also the Volume force density by selecting the whole magnet and then right click> Fields> Other> Volume_Force_Density
      I hope this helps!
      • hector
        Thanks for the response. This shows the force field. Is there any way to show the resultant force vector?
  • The topic ‘Is there a way to display a force vector in Maxwell?’ is closed to new replies.
