July 11, 2023 at 3:34 am
hone zifu
Subscriber -
July 11, 2023 at 8:11 am
Forum ModeratorFor powder milling? I suspect you'll want Ansys Rocky for that.
July 11, 2023 at 8:16 am
hone zifu
SubscriberMy idea is to use fluent to calculate the amount of grinding of the object. I am currently doing CMP analysis and need to simulate the amount of grinding
July 11, 2023 at 8:21 am
Forum ModeratorPlease can you explain with pictures? I have no idea what the CMP analysis means, but may recognise it by a different name.
July 11, 2023 at 8:23 am
July 11, 2023 at 8:39 am
Forum ModeratorIf you can relate wall shear stress to grinding, yes. There's not a model in Fluent that'll do this directly.
July 11, 2023 at 8:55 am
hone zifu
SubscriberHowever, the model I set is to set water and air for vof. At present, only the flow field of water can be made.
hone zifu
SubscriberHow should I set up according to your suggestion, thank you -
July 11, 2023 at 9:16 am
Forum ModeratorLinking shear to grinding? You need a correlation and you can then use a Custom Field Function (or UDF) to plot the value of the supplied correlation.
July 11, 2023 at 9:18 am
hone zifu
SubscriberIf looking at shear alone, do I just need to set the shear force on the surface
July 11, 2023 at 9:20 am
Forum ModeratorYou'd be using not setting the value. It depends on what correlation you have and want to use. I can't help you with the what, that's for your literature review to figure out.
July 11, 2023 at 9:22 am
hone zifu
SubscriberBecause the literature I read is mainly based on experiments, and I have not found anyone using fluent to calculate the amount of grinding.
July 11, 2023 at 10:10 am
Forum ModeratorFluent doesn't have a grinding model. Fluent can give you parameters that can be used in an experimentally derrived correlation to calculate a grinding rate. So you can do the experiment on a simple, safe system and employ Fluent for complicated, dangerous and expensive enviroments as part of the design process.
July 12, 2023 at 3:36 am
hone zifu
SubscriberThen if I set vof and DPM model to set water and particles for flow field analysis, can I know that the particles are in contact with the surface?
July 12, 2023 at 10:03 am
Forum ModeratorYou can check their position. There's also the erosion and accretion model(s), but they're designed for impact effects rather than grinding. However, if it's a high volume fraction of solids DPM isn't appropriate.
July 13, 2023 at 9:09 am
hone zifu
SubscriberThen I would like to ask how to set the proportion distribution of the liquid mixture concentration
July 13, 2023 at 9:21 am
Forum ModeratorOf the DPM? Once they're in the system the particles will do where the flow takes them. Volume injection may be appropriate, but I don't think you want DPM for this. Is the liquid a high volume fraction slurry?
July 14, 2023 at 4:08 am
hone zifu
SubscriberBecause my current idea is to flow into the pure liquid with a volume fraction of 1 first, then flow into the grinding dope after 30 seconds, and judge the distribution volume of the dope
July 14, 2023 at 8:05 am
Forum ModeratorAnd would the grinding dope mix with the liquid? Is it a slurry?
July 14, 2023 at 5:44 pm
hone zifu
SubscriberYes, I'm going to do VOF for this part or component transfer is better
July 17, 2023 at 7:42 am
Forum ModeratorIf it mixes I'd potentially use species, but I'd also look at nonNewtonian viscosity for the slurry to avoid needing the solids. There's a fair bit of literature covering this - blood and sewage sludge being two fluids I've seen represented in this way.
July 18, 2023 at 7:13 am
hone zifu
SubscriberI don't intend to incorporate solid materials; instead, I plan to mix fluids with a density of one (water) with different densities.
July 20, 2023 at 2:48 am
hone zifu
Subscriber -
July 20, 2023 at 2:56 am
July 20, 2023 at 8:20 am
Forum ModeratorImmiscible and VOF, so the fluids shouldn't mix. If that's the phase volume fraction then the above looks sensible for that definition and model.
July 20, 2023 at 8:48 am
hone zifu
SubscriberIf it is a hybrid VOF method, how should I modify the settings?
July 20, 2023 at 10:23 am
Forum ModeratorYou mean multi-fluid VOF? It's set from the Eulerian panel, but that's still two (or more) phases.
July 24, 2023 at 5:09 am
hone zifu
Subscribermean? Also, I have another operational issue - I can't select the folder to save while creating animations."
July 24, 2023 at 5:13 am
July 25, 2023 at 8:48 am
Forum ModeratorAre you running in Workbench?
July 25, 2023 at 8:51 am
hone zifu
SubscriberYES
July 25, 2023 at 9:20 am
Forum ModeratorWB sets all save locations etc to avoid files being lost.
July 25, 2023 at 9:22 am
hone zifu
SubscriberWhat I mean is that I cannot select the option to set the animation folder in Fluent.
July 25, 2023 at 10:01 am
Forum ModeratorBecause you're using Workbench. Fluent locks down the save options.
- The topic ‘Is there a way to calculate the grinding consumption through FLUENT’ is closed to new replies.
5984
1307
