Is there a problem with my geometry?
    • Whiteney1991
      Attached is an image of my geometry (a cylinder closed on one end and with a flange at the open end). In GEOMETRY it appears as intended but in the MODEL, it has the erroneous geometrical attachments highlighted in blue. Kindly advise on how I can eliminate parts surrounded by blue ink.
      Do these erroneous geometry attachments have an effect on the simulation results in Transient Thermal?
      Thank you
    • 1shan
      ,nCould you try meshing the part and see if this irregularity persists. If the mesh looks ok, (follows the actual geometry) you should be good.nnRegards,nIshan.n
    • Whiteney1991
      Thank you Array. The geometry looks okay when meshed. However, the results obtained are incorrect...they give an error message of solution time exceeding CPU time. I have followed the thread of this error message and have commented to seek help. n
  • The topic ‘Is there a problem with my geometry?’ is closed to new replies.
