Is it possible to simulate particles merging and breaking by DPM model?
December 12, 2024 at 9:18 am
luna6362
SubscriberHello! I am simulating the oil particle in compressor to see the distribution by DPM model.
I understand that DPM model just calculate the interaction between the particle and the fluid.
But I want to see the particles merging and breaking by trainsient DPM model.
Is it possible? Or should I use UDF to acheive the result I want to see?
Thank you so much!!
December 12, 2024 at 10:23 am
Forum ModeratorHave a look at the Stochastic Collision and break-up models: DPM Physical Models. Do NOT use DEM collision for this application. You may also want to review the wall film models.
December 12, 2024 at 12:20 pm
luna6362
SubscriberHello Rob! Nice to see your answer again!!😆
Thank you for your suggestions. I will have a look at those models.
But I am wondering if the Stochastic Collision and break-up models can make paricles merge?🤔
December 12, 2024 at 2:11 pm
Forum ModeratorTurn on collision and the break up option should also appear. Don't ask....Â
December 12, 2024 at 2:13 pm
luna6362
SubscriberOkay. Thank you so much!
5824
