November 13, 2023 at 12:52 pm
Yethreb.BENMESSAOUD
SubscriberHi,
I am working on a project where I have some errors. I can't have a Check Geometry without errors until now. Every time I delete the error faces and the non-manifold vertex, they keep coming back.Â
My question is : Is it possible to continue the merge and the volume extraction while having errors or it is necessary to have a 100% clean geometry ?
Thank you.
November 15, 2023 at 1:36 pm
Aniket
Forum ModeratorIt is recommended to have a clean geometry, but, if you are not able to recreate entities with errors, you may try to mesh them and use measures like defeaturing tolerance, virtual topology, etc. but if this does not work, cleanup at geometry level is recommended.
-Aniket
- The topic ‘Is it possible to merge bodies when there are errors in Check Geomtry ?’ is closed to new replies.
1530
1386
1209
