Is it possible to have an object naturally move or rotate as if its actually surrounded by a moving fluid (to find TSR)
January 15, 2023 at 1:07 pm
Nirvaan Chadda
SubscriberI would like to find the TSR of different wind turbine designs but I am not sure how I would make the turbine move due to the wind.Â
Also, how would I get numerical results of torque and power (coefficient).
January 16, 2023 at 1:04 am
Subashni Ravichandran
Forum ModeratorHello Nirvaan Chadda
Are you using Ansys Discovery?
In Discovery, you can apply force/torque to a body to replicate this effect, but Fluid Solid interaction simulations are currently not possible.
You can try using Ansys Workbench for the same.
January 22, 2023 at 11:48 pm
I would be able to help you better if you can share the simulation file with me.Â
I will be sharing a Secure Transfer link via email. Please use the link to share your model.
January 25, 2023 at 12:10 pm
Please check your email for some sample files I have shared. As there is no FSI capability as I have specified before, you will need to directly apply the fluid pressure on the blades.
Please note the Imprint tool needs to be used to apply both bonded contacts and fixed support on the axel.Â
- The topic ‘Is it possible to have an object naturally move or rotate as if its actually surrounded by a moving fluid (to find TSR)’ is closed to new replies.
- Unable to attach geometry 2024 R2
- Data Center Simulation
- [SpaceClaim] STEP file size using Converter.exe
- How to do the snap fit insertion FEA?
- Spaceclaim 2024 error FNE activation failed
- Ansys Discovery Crashing vGPU (Reproducible)
- PMI Product manufacturing information in SpaceClaim/Discovery modeling
2778
965
841
599
591
