December 20, 2019 at 10:51 am
tayyaba.bano
SubscriberHi
I hope you are doing well, I am currently working with Fluid Structure
Interaction (FSI) using Ansys Workbench . My
question is as follows:
in coupled FSI I use the following:
1. Geometry
2. Transient Structure
3. Fluid flow
4. System coupling
is it possible to disconnect transient structure and system coupling
from Fluid flow at certain time and to see the influence of only Fluid
flow?
Waiting for your kind response.
Regards
Tayyaba Bano -
December 20, 2019 at 2:36 pm
Forum ModeratorYou can take data from Fluent (pressure, temperature etc) from Fluent into Mechanical and use that. Is that what you want?
December 26, 2019 at 11:39 am
tayyaba.bano
SubscriberThank you very much for your kind reply, if I want to see only fluid influence for certain time without structure motion just in the case of CFD , then is it possible by Ansys Workbench to shift FSI to CFD, by disconnecting the system coupling and transient structure from fluid flow?
Kind regards
Tayyaba
- The topic ‘Is it possible to discoect system coupling and Transient structural from fluid flow in FSI?’ is closed to new replies.
3597
1243
1092
1068
953
