Is it possible to compile an UDF to alter the height of vertical wall during the course of solution?
    • subhamcfd
      I am simulating a 2D hydraulic jump in a rectangular 2d channel. I have a tail-gate at the outlet such that the flow get obstructed by the gate and in due course of time, the water flows over the gate. But , as of now, i have to run the calculations considering fixed height of tail gate and as such , during the calculation , i can not alter the height of tail-gate . As a result , my depths of flow pre-jump and post jump can not be altered and the location of jump also can not be altered.
      I intend to create a UDF , so that i can interrupt the calculation after certain iterations and alter the height of tail gate i.e lower or raise the tail gate. I expect the solver to consider this effect upon resuming the calculation.
      Is it possible to compile such an UDF? Or is there any simpler process to achieve the above task.
      Do you want to model the gate in motion or just have a sudden change in height? You also need a lot more mesh if you want to resolve the free surface.
    • DrAmine
      Is the tail gate modeled as a wall? Or Pressure Outlet?
    • subhamcfd
      Mr. Rob , I want to model the gate such that , i would be able to lower or raise the tail gate (basically a wall) at any time within the solution. Of course , I will interrupt the solution and then raise the gate and resume the solution like in any physical experiment.
      Mr. DrAmine , tail gate is modelled as a wall.
      I assume this is transient. In that case you could also split the mesh or relabel a zone(s). To do this accurately you'd need to pre-plan the positions to then split the mesh afterwards.
Viewing 4 reply threads
  • The topic ‘Is it possible to compile an UDF to alter the height of vertical wall during the course of solution?’ is closed to new replies.
