3D Design
3D Design
IronPython DocumentInsert
    • scdm05
      ? This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
      Hello I am working on STL file import / SCDM V2020R2
      # Python Script, API Version = V19
      # PATH VARIABLE
      Lattice_Path="C:\temp\Lattices\F"
      Var_Lattices = "1"
      Lattice_Extension=".stl"
      Lattice_Import=Lattice_Path+Var_Lattices+Lattice_Extension
      importOptions = ImportOptions.Create()
      DocumentInsert.Execute(Lattice_Import)
      The piece is imported, no problem If I change Var_Lattices to 2 ... it is still ok, F2.stl Loaded   But I am developping for End Users, so I need a User interface
      # PATH VARIABLE
      Force_Lattice = "None", "1", "2"
      def cmd_Import_Lattice():
          if combo_Lattice.Value == "1" :
              MyLattice = "F1.stl"
              FileToLoad= str(Lattice_Path+MyLattice)
              DocumentInsert.Execute(FileToLoad)
          if combo_Lattice.Value == "2" :
              MyLattice = "F2.stl"
              print MyLattice
      combo_Lattice = Beta.InputHelper.CreateComboBox("Force : ","help msg", Force_Lattice)
      button_Lattice_Ini = Beta.InputHelper.CreateButton(cmd_Import_Lattice, ">>> Import", "help msg")
      groupe1 = Beta.InputHelper.CreateOptionsGroup("Ini",combo_Lattice,button_Lattice_Ini)
      result = Beta.InputHelper.PauseAndGetInput ("TITLE, Lattices", groupe1)
      The file 1 from combo is well imported but the script is still running ... so SCDM is not usable anymore, need to kill the process from Task Manager   So any idea are welcome ! Thanks Olivier
    • scdm05
      # PATH VARIABLE
      Lattice_Path="C:\temp\Lattices\"
              print MyLattice
      Sorry ... Latice_Path error corrected ... but still looping
    • subashni.satish
      Hello CFAO Bourjat
      Is this issue resolved? Did the script run or is it still looping?
    • scdm05
      Hello
      Still looping
  • The topic ‘IronPython DocumentInsert’ is closed to new replies.
