December 31, 2021 at 6:03 pm
hamoudy
Subscriberso in my Case
one cylinder have to be fixed and rotatote and i have define for it the following Conditions
1) Fixed support
2) Drehmoment so it can rotate with the given Moment
the second Cylinder have to (move) into the first fixed Cylinder and apply a certain Pressure
1) i put Cylinder support and Displacment on it
2) the Pressure
the results are not showing as expected
January 5, 2022 at 2:07 pmJohn Doyle
Ansys EmployeeI am not sure, but you mention "...the second Cylinder have to (move) into the first fixed Cylinder and apply a certain Pressure"
How and where is the pressure being applied? Is it causing a Hertzian stress between the two cylinders along top and bottom perhaps?
It appears the plot you are showing is for end of LS1. Are all the loads being applied in one loadstep?
Perhaps you have considered this already, but if not, sometimes it helps to apply these loads across multiple loadsteps to get a better understanding of the influence of each load. (i.e. Apply moment in LS1, Apply Pressure in LS2...)
January 9, 2022 at 5:28 pmhamoudy
Subscriberwell its supposed to be a static simulation
so i dont wanna do it in 2 steps
January 9, 2022 at 5:29 pmhamoudy
SubscriberAlthough i did change the Drehmomentum to rotional velcotiy there is no rotation show in my Simulation
it shows the right results tho.
January 9, 2022 at 10:06 pmpeteroznewman
SubscriberA Rotational Velocity load from the Inertial category in a Static Structural model does not cause any parts to rotate so will not cause any wear.
You need to use a Transient Structural model to rotate parts and cause wear.
January 10, 2022 at 8:45 pmhamoudy
Subscriberhey Peter thank you so much
i did find that after reading alot about stastic -Models
thank you so much
January 10, 2022 at 8:48 pmhamoudy
Subscriberon the other Hand i have a Question to you or to any one who can actually help
iam getting that the Gap should be in a wider Ranger compared actually to where the Frictional stress is acting and i would love to know where is the error or problem if there is any ?
i did add the Project archiv if u wanna have a look at it
thanks in Regards
January 10, 2022 at 9:12 pmhamoudy
Subscriberwhat i actually mean
isnt all the red part in Gap
should also be red in Frictional stress
Viewing 7 reply threads- The topic ‘investigation of wear between two cylindrical objects’ is closed to new replies.
2878
970
852
599
591
