October 4, 2017 at 12:20 pm
vganore
Ansys EmployeeThe CINT command is used to calculate the fracture mechanics parameters. The CINT command cannot be used with SHELL elements. SOLID elements are required. For a thin structure, you could use an overall surface model with SHELL elements and a local submodel with SOLID elements. The fracture mechanics parameters could be evaluated for the submodel.
October 4, 2017 at 2:39 pm
pgl
Ansys EmployeeHow to investigate fracture mechanics parameters for a thin geometry?
- The topic ‘Investigate fracture mechanics parameters for a thin geometry’ is closed to new replies.
1307
