TAGGED: ansys-innovation-courses, fluids, laminar, viscous
October 1, 2020 at 9:31 pm
Karthik Remella
AdministratorOctober 1, 2020 at 9:31 pmKarthik Remella
AdministratornnJanuary 19, 2021 at 8:04 pmtroxlerc
SubscriberThis is a good course but several of the examples discussed involve Turbulent Flow, a better name would Viscous Flows rather then Viscous Laminar Flows. Excellent course other than that error. nJanuary 20, 2021 at 2:03 pmKarthik Remella
AdministratorHello,nI agree that the simulation examples covered in this course, with the exception of 'Blood Flow through the Circle of Willis' (link below), use the turbulence models. The reason for including these examples is most flows in engineering applications are turbulent in nature. Very flow applications involve a laminar flow.nAlso, if you go through the individual lessons on external and internal flows in this course, we cover various viscous laminar concepts involving:nCreeping flow past a sphere - Stoke's solutionnOseen's correction to Low Re laminar flownCouette flow between flat plates and rotating concentric cylinders, and nPoiseuille flow (incl. Hagen-Poiseuille flows)nIn addition to highlighting some laminar flow applications, we also wanted to give a flavor for some important engineering applications in our course. Because of all these reasons, the name of this course is - Viscous Laminar Flows.nMoreover, in the Learning Track - 'Basics of Fluid Dynamics', we cover quite a few simulation examples involving laminar flows. To name a few: nFalling Sphere Viscometer (What are Fluids?):nPitot Tube (Course - Simple Approximations of Fluid Flows):nI hope this addresses your question.nBest Regards,nKarthiknViewing 3 reply threads- The topic ‘Introducing: Viscous Laminar Flows’ is closed to new replies.
5654
1885
1404
1303
