Interupting client does not work!?
    • abhishekkumar.shingala
      Hello everyone, In the fluent software when I try to modify cells or use tet improve and perform operation, it takes too much time and in anycase if I try to interupt the client using ctrl + c in the console, it never stops running. does anyone know any other way to stop operation? why fluent does not have a stopping button?
      Stop usually works, and CTRL+C also stops the solver. You may need to hit CTRL+C a couple of times if you're running transient.
      Some operations, DPM tracks and mesh processes don't have an interrupt as doing so could corrupt the update. These processes can take a few minutes, longer if you accidentally set something incorrectly or your change/update is large relative to the compute hardware.
  • The topic ‘Interupting client does not work!?’ is closed to new replies.
