April 8, 2020 at 10:20 pm
Faryal
SubscriberI am unable to interpret the properties i find on matweb and other resources to the engineering data of ANSYS. In matweb fatigue strength is given, elongation at break is given, elongation at yield is given but in ANSYS there is no elongation in yield and because of the lack of properties in the Engineering Data the stress strain graph i am getting is not the same as the theoretical.
April 9, 2020 at 2:40 pm
Forum ModeratorIsn't that covered in one of Poisson Ratio & Young's Modulus? I'm a fluids specialist, so just have to worry about material thermal properties most of the time.Â
April 9, 2020 at 8:17 pm
Faryal
SubscriberIt doesn't give me a conventional stress strain graph that becomes non linear when elastic limit is reached. When i added the plastic property of yield strength then it does become nonlinear at some point but it doesnt resembles the PLA graph that is in literature. In ANSYS the names of properties are different than the ones i get on datasheets.
April 10, 2020 at 12:36 am
peteroznewman
Subscriber You should get your Engineering Data from CampusPlastics.com
- The topic ‘Interpreting Material Properties in Engineering Data’ is closed to new replies.
5124
1831
1387
1248
