Interpolation methods
    • ashiadarsh
      What is the difference between the various interpolation methods under the profile tab in ANSYS FLUENT?
      There are three interpolation methods-Constant,Inverse distance & Least squares
      If we are having lesser data points and to have smooth curve between these points which method of the above should we choose?
      Thank You
      Adarsh
    • raul.raghav
      Below is a screenshot from Ansys help which explains the 3 interpolation methods.
    • Keyur Kanade
      thanks raul for pitching in.
      adarsh, if this helps you then please mark this as 'is solution' to help others on forum.
    • ashiadarsh
      I tried by increasing the number of data points.It worked for me.
      Thank You
      Adarsh
  • The topic ‘Interpolation methods’ is closed to new replies.
