April 24, 2024 at 8:15 am
xile.shao
SubscriberHi all,
I'm reaching out to seek clarification regarding the extraction and interpolation of velocity data for DPM (Discrete Phase Modeling) post-processing based on a Fluent case. Specifically, I aim to display the velocity experienced by the particles along their trajectories. To achieve this, I understand that I need to extract velocity data and perform interpolation akin to DPM.
My current understanding is that I should obtain velocity data co-located at the face centers and then conduct a linear interpolation for each component. Could someone kindly confirm if my understanding is accurate? Additionally, could you advise on the specific variables I should use to extract the velocity data?
I appreciate any guidance or insights you can provide on this matter. Thank you for your assistance. Best regards,
XS
April 24, 2024 at 1:00 pm
Forum ModeratorYou could extract the DPM track and get the particle velocity from that. Or do you need the cell values. You need to be a little more careful defining what you want, DPM Velocity (per track), DPM Velocity (per cell) or fluid velocity per cell.Â
You may find some of the definitions here helpful  https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v241/en/flu_ug/flu_ug_fvdefs.html Also, post processing for DPM is covered in the User's Guide.Â
- The topic ‘Interpolation method for dpm post processing’ is closed to new replies.
5824
