TAGGED: bolt, bolt-pretension, error, static-structural
March 5, 2024 at 4:13 pm
I am doing a static structural analysis on a pipe support clamp. The clamp has an upper (1) and lower section (2) that is held together with two bolts. The two mating clamp faces have a frictional contact of 0.2. The bolt head also has a frictional contact with the top clamp face, while the threaded part of the shank uses a bonded contact with the lower clamp. I have applied a 6180N pretension to the bolts.
There are various forces applied on the clamp device:
The model:
The bolt:
The mesh:
I keep getting the errors:
An internal solution magnitude limit was exceeded. (Node Number 158886, Body Unknown, DOF UX)
and
Solver pivot warnings or errors have been encountered during the solution.
I'm not sure what is causing these errors as the other pretensions I have for the rest of the bolts in the model all allow it to solve fine. Any ideas? Thanks
March 6, 2024 at 7:50 am
Akshay Maniyar
Ansys EmployeeHi,
It looks like the model is experiencing a rigid body motion. Can you check the initial information by inserting the contact tool? Also, share the screenshots of loads and boundary conditions. Please check the below course on Rigid body motion for more details.
Rigid Body Motion in Contact | Ansys Innovation Courses
Thanks,
Akshay Maniyar
March 6, 2024 at 2:46 pm
dlooman
Ansys EmployeePerhaps you could temporarily support the model while applying the bolt pretension. Also you could use weak springs to hold the model together. The message means that one of the parts has displaced by more than 1e6 inches/mm/meters depending on what your length unit is.
March 6, 2024 at 7:06 pm
mjmiddle
Ansys EmployeeIn what load steps were these loads applied? You should not apply them all at once. For bolt pretension, you should only load the bolt pretensions in a 1st load step. Only use enough supports and displacements to hold the model from rigid body motion in that 1st load step. Then in 2nd load step and any later load steps, you can "lock" the bolt pretension and apply your other loads.
- The topic ‘Internal solution magnitude limit – Pretensioned bolts’ is closed to new replies.
6785
1331
1147
