June 5, 2024 at 4:16 pm
July 3, 2024 at 9:42 am
ErKo
Ansys EmployeeÂ
Hi
There are many posts on this type of error message (means something is free and not connected and then we can not solve this).
See posts on search:
All the best
Erik
July 5, 2024 at 3:01 pm
dlooman
Ansys EmployeeAn easy way to check for unconstrained bodies/model is a modal analysis. A modal won't fail due to this issue and an unconstrained body will produce a zero frequency and some rigid body motion.
July 15, 2024 at 4:37 pm
Noha Elkersh
SubscriberThank you for your reply,
I tried all these solutions so this error disappeared, however another error showed up ( An Unknown error occured during the solution)
Could you be please check the model and tell me what is the exact problem, here is the link https://drive.google.com/file/d/1gRqbf1wWZy8T49B9UwwK3VUhNUVCJTnm/view?usp=sharing
July 16, 2024 at 2:59 pm
dlooman
Ansys EmployeeUnfortunately we can't check models through forum support.
- The topic ‘Internal solution magnitude’ is closed to new replies.
5814
