December 2, 2024 at 12:46 pm
gambra77
SubscriberHello,
i simulate one body that i´ve simulated before but changing some parametres and these messages are shown;
*** ERROR ***Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â CP =Â Â Â Â Â 16.359Â Â TIME= 13:32:49
 The value of UX at node 64430 is 3.328084258E+13. It is greater than Â
 the current limit of 1000000 (which can be reset on the NCNV command).Â
 This generally indicates rigid body motion as a result of an         Â
 unconstrained model. Verify that your model is properly constrained. Â
 *** ERROR ***                          CP =     16.359  TIME= 13:32:49
 *** MESSAGE CONTINUATION ---- DIAGNOSTIC INFORMATION ***              Â
 If one or more parts of the model are held together only by contact   Â
 verify that the contact surfaces are closed. You can use the CNCHECK Â
 command to check the initial contact status in the SOLUTION module.Â
i dont know if they are related to de conections.
December 2, 2024 at 1:14 pm
mohan.urs
Ansys EmployeeÂ
Hey,
The error suggests that there is some rigid body motion is present in the model. It happens due to under constrained model or contacts.
https://innovationspace.ansys.com/courses/courses/prevent-rigid-body-motion-in-contact/ Check this link to debug the problems in contact.Regards,
Mohan UrsÂ
