August 28, 2023 at 4:55 pm
September 6, 2023 at 12:31 pm
Murari Iyengar
Ansys EmployeeHi, we cannot access any links as part of the Ansys Policy. Can you share screenshots of the Battery modeling settings?Â
September 7, 2023 at 3:59 pm
Nitesh Gupta
Subscriberhey Murari,Â
Any Success?
September 6, 2023 at 7:52 pm
September 8, 2023 at 2:43 pm
Murari Iyengar
Ansys EmployeeHi Nitesh, how did you patch the short resistance? It should be a small region. Start with large short resistance value first and run it. See the effect and then lower it if it is needed.Â
September 8, 2023 at 2:49 pm
Nitesh Gupta
SubscriberHow can I improve? Or, what can be the problem. Any suggestions? Why the solver blows up at lower resistances even though i used small time step.
September 8, 2023 at 2:47 pm
Nitesh Gupta
SubscriberYeah, i already tried it. I started with 500 mohm in a volume of 5x5x5mm. But I am not able to run at 70mohm and I need it to run at that value.Â
Viewing 4 reply threads
- The topic ‘Internal Short ckt modeling for Li-ion battery using Newman P2D model’ is closed to new replies.
