November 25, 2023 at 4:13 pm
Saad Ahmed
SubscriberHello, I am doing an internal flow CFD in FLUENT in a hollow rectangular channel. The outer body steel, is a t constant surface temperature of 600K and the interior fluid is water at 300K.
Firstly, I want to plot the mass-averaged fluid temperature vs the flow axial direction. I have not found a plot option of plotting the surface reports in ANSYS FLUENT.
Secondly, how can I calculate the heat transfer rate between the wall and fluid in FLUENT. -
November 26, 2023 at 11:25 am
- The topic ‘Internal Channel Flow – Heat Transfer CFD’ is closed to new replies.
