May 14, 2024 at 3:37 pm
Daniel Sami HAMADE
SubscriberHello,
I am trying to build an interference fit simulation between two steel cylinders in a 2D plane stress or plane strain model of a 30 degres pie slice.ÂI tried to follow in details all the recommendations in the links below:
/forum/forums/topic/basic-interference-fit/
/forum/forums/topic/interference-fit-pressure/
https://youtu.be/5jH2Ox6-YkU
The problem is that I am getting a FEA contact pressure of 83 MPa, whereas the theoretical value is 75 MPa ! (same materials: E=200 000 MPa, vu=0.3, dimensions given in below Figure).
Could you help me solving this issue ? any recommendations ?You can find below the links to the Ansys Archive .wbpz fileÂ
--> Model1.wbpz
I also tried to build the same model in a 2D axisymetric view, but I also get 83 MPa and not 73 MPaÂ
--> Model2.wbpz
Thanks in advance,
Sami
May 15, 2024 at 12:32 pm
peteroznewman
SubscriberHello Sami,
I looked at your model and found it is very well done. It has a good mesh and all the boundary conditions are correct.
I used an online calculator that uses Lame's equation to calculate the Interference pressure for the values in your model and it came up with 81.5 MPa which is close to the Ansys result of 83 MPa.
Peter -
May 16, 2024 at 10:55 am
Daniel Sami HAMADE
SubscriberÂ
Hello Peter,
Thank you so much for solving my problem! ????
I had entered a wrong value for d0 in my calculations.
Just one last question concerning the values your entered in the online calculator.
If I use d=119.4 mm instead of d=120 mm –> I get a pressure of 82.3 MPa.
I consider that d is the nominal diameter of the interface (after press-fit), based on:
Norton Machine Design Integrated Approach – Norton
Shigleys Mechanical Engineering Eighth Edition Design – Budynas Nisbett
Sami
May 16, 2024 at 9:09 pm
peteroznewman
I did no testing of the online calculator and didn't lookup the equation in Shigley's, but it seems you have an Ansys model that agrees with Shigley which is encouraging.
Peter
- The topic ‘Interference-fit-between-two-steel-cylinders’ is closed to new replies.
5719
