August 25, 2021 at 5:57 pm
Dubey92
SubscriberI am modeling laser melting in FLUENT using solidification/melting and VOF. There are a number of particles over a solid substrate and there is an inert gas atmosphere above them. Now, the laser energy is a surface heat source. I need to convert it into volumetric heat source and then apply it into the interfacial cells between the metal particles and the gas. I need 2 things for this:
- Gradient of volume fraction of a phase in a cell(C_VOF_G) to convert the surface source to volumetric source. I understand that FLUENT does not have a macro for gradient of volume fraction. How to get the gradient of volume fraction?
- When the laser will melt the particle, volume fraction in the cells will change and hence the interface. How to track this interface using a UDF so that laser is applied on the interfacial cells?
Till now I have been using the following code and it compiles without any error, When I give an inlet velocity for the gas domain and an outlet, the simulation runs although the results are not correct. When I make the gas domain stationary , the simulation completes without anything happening. Any help is much appreciated.
Thank you
DEFINE_ADJUST(adjust_gradient_heat, domain)
Thread *t;
Thread **pt;
cell_t c;
int phase_domain_index = 1.0;
Domain *pDomain = DOMAIN_SUB_DOMAIN(domain,phase_domain_index);
Alloc_Storage_Vars(pDomain,SV_VOF_RG,SV_VOF_G,SV_NULL);
Scalar_Reconstruction(pDomain, SV_VOF,-1,SV_VOF_RG,NULL);
Scalar_Derivatives(pDomain,SV_VOF,-1,SV_VOF_G,SV_VOF_RG, Vof_Deriv_Accumulate);
mp_thread_loop_c(t,domain,pt)
if (FLUID_THREAD_P(t))
Thread *ppt = pt[phase_domain_index];
begin_c_loop (c,t)
C_UDMI(c,t,0) = C_VOF_G(c,ppt)[0];
C_UDMI(c,t,1) = C_VOF_G(c,ppt)[1];
C_UDMI(c,t,2) = C_VOF_G(c,ppt)[2];
C_UDMI(c,t,3) = sqrt(C_UDMI(c,t,0)*C_UDMI(c,t,0) + C_UDMI(c,t,1)*C_UDMI(c,t,1) + C_UDMI(c,t,2)*C_UDMI(c,t,2));    // magnitude of gradient of volume fraction                                Â
C_UDMI(c,t,4) = C_UDMI(c,t,0)/C_UDMI(c,t,3);Â Â Â Â Â Â Â Â // nx -> x gradient of volume fraction divided by magnitude of gradient of volume fraction
C_UDMI(c,t,5) = C_UDMI(c,t,1)/C_UDMI(c,t,3);Â Â Â Â Â Â Â Â // ny -> y gradient of volume fraction divided by magnitude of gradient of volume fractionÂ
C_UDMI(c,t,6) = C_UDMI(c,t,2)/C_UDMI(c,t,3);       // nz -> z gradient of volume fraction divided by magnitude of gradient of volume fraction                                            Â
end_c_loop (c,t)
Free_Storage_Vars(pDomain,SV_VOF_RG,SV_VOF_G,SV_NULL);
DEFINE_SOURCE(heat_source, c, t, dS, eqn)Â Â Â Â Â Â // The name of the UDF is heat_source
Thread *pri_th;
Thread *sec_th;
real source;
real x[ND_ND], time;Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â // Define face centroid vector, time
time = RP_Get_Real("flow-time");Â Â Â Â Â Â Â Â Â Â Â Â Â // Acquire time from Fluent solver
C_CENTROID(x, c, t);Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â // Acquire the cell centroid location
real T = C_T(c,t);
pri_th = THREAD_SUB_THREAD(t, 0);
sec_th = THREAD_SUB_THREAD(t, 1);
real alpha = C_VOF(c,sec_th);Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â // cell volume fraction
real gamma;
if (T>293.0 && T<1658.0)
gamma = 0;
else if (T>=1658.0 && T<=1723.0)
gamma = (T-Ts)/(Tl-Ts);
else if (T>1723.0)
gamma = 1;
real Pv = 0.54*Pa*exp((Lv*M*(T-Tv))/(Rg*T*Tv));
real mv = (0.82*M*Pv)/(sqrt(2*Pi*M*Rg*T));
real rhos = 7900;Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â // density of solid SS316
real rhol = 7433 + 0.0393*T - 0.00018*pow(T,2);Â Â Â Â Â Â // density of liquid SS316
real rhom = rhol*gamma + rhos*(1-gamma);Â Â Â Â Â Â Â Â Â Â // density of SS316
real rho = alpha*rhom + rhog*(1-alpha);Â Â Â Â Â Â Â Â Â Â // density of cell containing metal and gas
real Cps = 462 + 0.134*T;Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â // specific heat of solid SS316
real Cpl = 775;Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â // specific heat of liquid SS316
real Cpm = Cpl*gamma + Cps*(1-gamma);Â Â Â Â Â Â Â Â Â Â Â // specific heat of SS316
real Cp = alpha*Cpm + Cpg*(1-alpha);Â Â Â Â Â Â Â Â Â Â Â Â // specific heat of cell containing metal and gas
real factor = (2*rho*Cp)/(rhom*Cpm + rhog*Cpg);
real r = sqrt(pow(x[0]-x0-v*time,2.0) + pow(x[1]-y0,2.0));
if(C_VOF(c,sec_th)>0.05 && C_VOF(c,sec_th)<1)
if(C_T(c,t) < 3090)
source = (((2*A*P)/(Pi*R*R))*exp((-2*(r*r))/(R*R)) - h*(T-Ta) - s*e*(pow(T,4) - pow(Ta,4)))*C_UDMI(c,t,3)*factor;
dS[eqn] = 0.0;
else if(C_T(c,t) >= 3090)
source = (((2*A*P)/(Pi*R*R))*exp((-2*(r*r))/(R*R)) - h*(T-Ta) - s*e*(pow(T,4) - pow(Ta,4)) - Lv*mv)*C_UDMI(c,t,3)*factor;
dS[eqn] = 0.0;
else
source = 0.0;
dS[eqn] = 0.0;
return source;
August 26, 2021 at 8:25 amAmine Ben Hadj Ali
Ansys EmployeeFluent calculates the gradients and once they are not required anymore they are reset and so on. You can keep memory from being freed : that is the official way to access gradients.
Laser Energy Source should be applied at the interface so in partial filled cells (Simple IF Condition).
August 26, 2021 at 11:39 amDubey92
SubscriberThanks for your suggestion. Till now, I have been using the following condition for applying the laser source in the interfacial cells:
Thread *pri_th;
Thread *sec_th;
But I am not sure if it is right. Then I read in a paper that the way to track the interfacial cells is to compare the coordinates of centroid of cells. If a cell has all the secondary phase and the above cell has volume fraction in between then I can use that z coordinate to apply laser source. Can you please tell which approach is correct? And should I use the above condition inside DEFINE_SOURCE or DEFINE_ADJUST?
August 26, 2021 at 11:46 amDubey92
SubscriberAs for the volume fraction gradients, which macro can I use to access gradient of volume fraction in my UDF as I understand that FLUENT does not have any macro C_VOF_G for accessing volume fraction gradient directly?
Viewing 3 reply threads- The topic ‘Interface tracking between 2 phases in VOF’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- air flow in and out of computer case
- affinity not set
Top Contributors-
3932
1414
1272
1119
1015
Ansys Assistant
Welcome to Ansys Assistant!
RETRY
