August 1, 2022 at 7:57 am
lancer
SubscriberHi, I'm currently doing research involving heat and reaction occuring from Fluid to Fluid Interface and Fluid to Solid Interface. I used Boolean in the Design Modeler, and in Setup I used the mesh interface feature to connect the two interface. But, when I want to select the interface, there is a lot of similar as per below:
My question is if I want to select the intf:08 or other, do I select all three of them such as intf:08-interior-1-1, interface_chccc-non-overlapping and interface_ccchc-non-overlapping. OR do I just select one of them?Â
or is this the wrong way to make interface?
August 1, 2022 at 10:23 am
Forum ModeratorThe easiest approach is to create a multibody part in DM as that'll give you a conformal mesh and you don't then need the interface zones. However, that looks like Fluent has automatically set up some/all of the zones so you may not need to do anything.Â
August 1, 2022 at 12:05 pm
lancer
SubscriberAny youtube channel or reference I can refer?
August 1, 2022 at 12:35 pm
Forum ModeratorHave a look in "Help" for tutorials and videos. Multibody parts are covered in DM, interfaces in Fluent.Â
August 1, 2022 at 2:26 pm
lancer
SubscriberTo tell you the truth, I have no idea like multibody part, conformal mesh. So I don't know what to click help or what tutorial to learn.
August 1, 2022 at 3:45 pm
Forum ModeratorDo all of them. The tutorials are intended to get you some way up the learning curve, YouTube gets you a bit further.Â
- The topic ‘Interface Selection’ is closed to new replies.
5819
