November 2, 2024 at 10:21 pm
karimi
SubscriberHi
I am trying to model teh flow in this system, that I have a non-porous fluid coming and interacting with a porous fluid and then leaves it to a non-porous fluid, and eventually the outlet. My inlet is the mass flow rate and my outlet is a pressure. The model initialize pressty good but I am having a serious problem with convergence. My mesh is really good quality and fine enough, my geometry is smooth and nice too. And I am sure my BCs are all correct, I just do not know if I missing something here. Maybe I need to define an interface between the porous and non-porous regions or change teh solver? my fluid is incompressible and just simple water. Would appreciate any helps and ideas here? My mesh is way finer than this pic so I am sure there is no problem with the mesh. I went to even 20 million elements fine mesh but still the same problem.
November 3, 2024 at 8:22 pm
karimi
SubscriberJust an update, I used both Steady and Transient methods. Also, decreased the permeability to a half, however, none of these helped me to get this converged.
November 4, 2024 at 10:08 am
Forum ModeratorWithout some idea of domain size, flow speed, mesh quality and many other factors it's difficult to comment. Some images of results (pressure & velocity are a good start) along with residuals may help.Â
November 5, 2024 at 6:21 pm
karimi
SubscriberThank Rob, so lets resolve this step by step. When I define a porous and a non-porous region, at their interfaces, Do I need to define a specific boundary condition like a porous jump or it can be treated just as a wall?Â
Also, when I define a fluid component as a porous, do I still need to define a porous jump or one of those will do the job for me?Â
November 6, 2024 at 9:30 am
Forum ModeratorIf you treat the boundary between porous & non-porous as a wall there will be no flow. The default boundary between the zones should be an interior, and I would generally leave it like that. About the only reason for using a PJ there would be to trap particles if the DPM model was being used.Â
November 8, 2024 at 8:38 pm
karimi
SubscriberRob,
I figured the conact between the porous and nonporus zone are being recognized as walls and this is why the flow cannot get out and I get divergence in continuity. However, when whatever I do I cannot transfer those contact regions/mesh interfaces to internal and fluent insist on recognizing them as walls. I am stuck and I do not know what to do with this? Appreciate your help
November 8, 2024 at 9:30 pm
November 12, 2024 at 1:51 pm
5669
1890
1419
1304
