April 18, 2023 at 11:19 am
David Robles
SubscriberHello,
I am developing a test model solution using Interconnect. In the model, I am using a EOM with a test signal to the circuit and I am trying to filter out the laser tone source signal. However, when I use the interconnect square filter, I am unable to fully filter out the laser source. I have also tried designing a ring resonator filter and had similar issues. Is there a solution that I might be missing in blocking out the laser signal in my simulation?
October 26, 2023 at 9:47 pm
Dev
Ansys EmployeeHello David, I hope you solved this issue. For Photonics questions please post in Photonics forum: Photonics (ansys.com).Â
- The topic ‘Interconnect Solution’ is closed to new replies.
- Add-in Error Excel
- Missing SubDivWrapper.dll
- Fileformats
- Discovery 2025r2 failed to initialize
1487
1363
1194
