July 5, 2020 at 3:23 pm
boonthiam13
Hi:
I am simulating an interaction between two beams. Basically the two beams are not in contact initially and their ends are fixed. A force is then applied on the other end of the upper beam to bend the upper beam, followed by the contact between the two beams. The images illustrate the deformation for the beams at different result scale. At true scale (the first image), the graphical result looks logical. Whereas at result scale higher than one, penetration and merging of the beams are observed. Is that normal?
Thanks!
Rgds,
Boon
July 5, 2020 at 7:36 pm
July 6, 2020 at 1:23 am
boonthiam13
SubscriberPeter, thanks for your information. Also, under what circumstances we still turn on the large deflection? As I have frequently encountered convergence issue after turning on the large deflection.
July 6, 2020 at 1:26 am
peteroznewman
SubscriberWhen a node moves more than the thickness of the section, large deflection should be turned on.
Turning on Large Deflection will make the solution take longer to compute, but it can't hurt the accuracy, it can only help.
July 6, 2020 at 2:36 am
boonthiam13
SubscriberNoted, cheers Peter!
- The topic ‘Interaction between beams’ is closed to new replies.
2838
970
851
599
591
