July 10, 2025 at 2:40 am
jdo60
SubscriberGood evening,Â
I am trying to pull INTER204 Output Results from a CZM Interface Delamination Sub-model, but the Strain Energy Density results are not present in the solution quantity worksheet. I have issued the OUTRES,ALL,ALL command in the Solutions Tree, but the Solution Worksheet does not update with the desired information. I am using Ansys 2025 R1 and running the sub-model in a transient structural module.Â
Is there something else I need to do to access this data?
INTER204 (ansys.com):
Regards,Â
Joshua -
July 10, 2025 at 8:25 am
July 10, 2025 at 8:36 am
Deepak
Ansys EmployeeHey Joshua, one more thing — the OUTRES command is a solution command, so it needs to be placed under the analysis settings block (/SOLVE). Thanks, Deepak -
July 11, 2025 at 1:42 am
jdo60
SubscriberThanks for your help, I will try putting the command under the analysis settings block.Â
Ansys Innovation Space
1057
1051
965
942
