Integrating Z-Axis Loads into a 2D ANSYS Simulation Using APDL
    • Jackely
      Dear ANSYS Users, In the course of my work with a 3D model in ANSYS, I am faced with the task of incorporating loads in the Z-direction. To enhance the efficiency of the simulation, I am considering the reduction of the model to a 2D format. I am seeking a method to implement the Z-direction loads using APDL. I would be grateful if you could share your experiences with similar simulation scenarios or any APDL commands that you have found effective.
      Thank you in advance for your assistance.
      Kind regards,
    • Tasos Zacharakis
      Hello Jackely,
      In a 2D analysis, the loads and results are in the x-y plane and there is no z component.
      Check this link for the requirements and limitations of the 2D analyses : 2D Analyses (ansys.com).
      Thank you,
      Tasos
    • Jackely
      Hello Tasos,
      Thanks for the info on 2D analyses. I understand now that leveraging the geometry's symmetry is the best approach to reduce computation time. Appreciate the advice.
      Jackely
  • The topic ‘Integrating Z-Axis Loads into a 2D ANSYS Simulation Using APDL’ is closed to new replies.
