July 16, 2024 at 8:40 am
tigers1227
Subscriberi want to integrate the journal file and mechanical script for automation.Â
I had some problems.
First. When you run the journal code, the UUID value, which is the material property value, changes and is saved every time, so this value cannot be specified when running a mechanical script.Â
So to solve this problem, I addÂ
material_name = matl1.Name
print("Material Name: {}".format(material_name))
with open(r'C:\Users\hyu3\Desktop\bar_example\material_name.txt', 'w') as f:
  f.write(material_name)Â
this code to journal file , and fix the mechanical script code like thisÂ
#region UI Action
with Transaction(True):
  body_21 = DataModel.GetObjectById(21)
  body_21.Material = material_name
#endregionSecond. I want to integrate this processes in one python code.
Can you give me any advice or guide line?Â
here is my full code about the journal file
# encoding: utf-8
# 2024 R1
SetScriptVersion(Version="24.1.144")# Static StructuralÂ
template1 = GetTemplate(
  TemplateName="Static Structural",
  Solver="ANSYS")
system1 = template1.CreateSystem()
favorites1 = EngData.LoadFavoriteItems()
library1 = EngData.OpenLibrary(
  Name="General Materials",
  Source="General_Materials.xml")
engineeringData1 = system1.GetContainer(ComponentName="Engineering Data")
matl1 = engineeringData1.ImportMaterial(
  Name="Stainless Steel",
EngData.EnableFilter(Enable=False)
EngData.EnableFilter()
geometry1 = system1.GetContainer(ComponentName="Geometry")
geometry1.SetFile(FilePath="C:/Users/hyu3/Desktop/bar_example/bar.stp")
modelComponent1 = system1.GetComponent(Name="Model")
modelComponent1.Refresh()
model1 = system1.GetContainer(ComponentName="Model")
model1.Edit()Â
And here is my mechanical script file codeÂ
# NOTE: All workflows will not be recorded, as recording is under development.
# Set the unit system
ExtAPI.Application.ActiveUnitSystem = MechanicalUnitSystem.StandardNMM
with open(r'C:\Users\hyu3\Desktop\bar_example\material_name.txt', 'r') as f:
  material_name = f.read().strip()#region UI Action
#endregion#region Details View Action
body_21.NonlinearEffects = False
body_21.ThermalStrainEffects = False
#endregion#region Context Menu Action
mesh_16 = Model.Mesh
sizing_39 = mesh_16.AddSizing()
selection = ExtAPI.SelectionManager.CreateSelectionInfo(SelectionTypeEnum.GeometryEntities)
selection.Ids = [30]
sizing_39.Location = selection
sizing_39.ElementSize = Quantity(5, "mm")
analysis_25 = DataModel.GetObjectById(25)
force_41 = analysis_25.AddForce()
selection.Ids = [26]
force_41.Location = selection
force_41.DefineBy = LoadDefineBy.Components
force_41.YComponent.Output.SetDiscreteValue(0, Quantity(-1000, "N"))
fixed_support_43 = analysis_25.AddFixedSupport()
selection.Ids = [28]
fixed_support_43.Location = selection
solution_26 = DataModel.GetObjectById(26)
total_deformation_45 = solution_26.AddTotalDeformation()
equivalent_elastic_strain_rst46 = solution_26.AddEquivalentElasticStrainRST()
equivalent_stress_47 = solution_26.AddEquivalentStress()
#endregionÂ
July 23, 2024 at 12:44 pm
Aniket Chavan
Forum ModeratorHello,
You can use something like:
Model.Geometry.Children[0].Children[0].Material="Structural Steel"
instead of using journal code.-Aniket
- The topic ‘integrate journal and mechanical script’ is closed to new replies.
