August 21, 2023 at 7:21 am
s.aruna
SubscriberHello,
In my system, the drive has 268 GB free; however, when I try to visualize the E-field from a frequency domain power monitor (2D Z-normal) for a Lumerical FDTD file with 22.9 GB size (after running the simulation), it is showing "The program must be terminated due to insufficient memory".
What can be the solution for this? Kindly help.
Thanks,
Aruna
August 22, 2023 at 9:40 pm
Guilin Sun
Ansys EmployeeIt is difficult to help since the informaiton is limited . 268 GB is the hard disk or memory? it needs large memory to display the data. It might also be related to display card memory.
- The topic ‘Insufficient memory to visualize E-field from a frequency domain power monitor’ is closed to new replies.
