Instantaneous Cut Water Plane Area
    • w.s.syafruddin2
      Hello
      In the hydrodynamic response, is it possible to obtain the cut water plane area of a structure in the time domain?
      Thank you
    • Yu Bi
      Hi, sorry, officially cut water plane area in a time domain analysis is not output. Some unpublic debug options can output it, however, those debug options didn't go through the quality check process and are also not clear enough for the users to recognize.
  • The topic ‘Instantaneous Cut Water Plane Area’ is closed to new replies.
