February 17, 2022 at 3:40 am
Altair45
SubscriberFebruary 17, 2022 at 9:46 pmLito
Ansys EmployeeAre you using CentOS 7.6 or newer? See this installation guide in our KB for more information. Try to change your folder/directory names to English. We have seen issues the folders are using non English characters.
Hope this helps.
February 18, 2022 at 12:55 amFebruary 18, 2022 at 1:18 amLito
Ansys EmployeeEnsure that the host and hostid information on the license file you are trying to add is the same as what is shown in the AnsysLMCenter -- View HostID information page.
If the HostName is different on the license file and the mac address is the same, edit the license file to the correct hostname on your server. If the mac address is different, you cannot use this license file on your server. Contact your Ansys Account Manager for a license server change with the correct license server hostid information.
SERVER1055
VENDOR ansyslmd PORT=1056
February 18, 2022 at 1:21 amFebruary 18, 2022 at 2:27 amLito
Ansys EmployeeFrom the error message in your screenshot, it indicates that you are missing the require libraries in Linux for the Ansys LM. Install the libraries:
sudo yum install lsb cyrus-sasl-lib libpng12 openldap
Viewing 5 reply threads- The topic ‘Installing Ansys license manager at CentOS 7’ is closed to new replies.
4783
1565
1386
1242
