February 8, 2021 at 4:47 pm
flavinho99
SubscriberHi, I just installed ansys but when I try to launch I have an error in startup scriptcan't read env(ANSYS_SYSDIR):no such variable while executingnn -
February 8, 2021 at 10:45 pm
ANSYS_MMadore
Forum ModeratorArray Can you please open a Windows command prompt and send the full output of the set command? Can you share the install.log file contents from C:\Program Files\Ansys Inc?.ThanksnMattn -
February 10, 2021 at 9:12 pm
dslondon1
SubscriberArray I have the same issue, here is the output of the set command.nC:\Users\David>setnALLUSERSPROFILE=C:\ProgramDatanANSYS211_DIR=C:\Program Files\ANSYS Inc\ANSYS Student\v211\ANSYSnAPPDATA=C:\Users\David\AppData\RoamingnAWP_ROOT211=C:\Program Files\ANSYS Inc\ANSYS Student\v211nCADOE_LIBDIR211=C:\Program Files\ANSYS Inc\ANSYS Student\v211\CommonFiles\Language\en-usnCommonProgramFiles=C:\Program Files\Common FilesnCommonProgramFiles(x86)=C:\Program Files (x86)\Common FilesnCommonProgramW6432=C:\Program Files\Common FilesnCOMPUTERNAME=GAMING-RIGnComSpec=C:\Windows\system32\cmd.exenDriverData=C:\Windows\System32\Drivers\DriverDatanHOMEDRIVE=C:nHOMEPATH=\Users\DavidnLOCALAPPDATA=C:\Users\David\AppData\LocalnLOGONSERVER=\\GAMING-RIGnLSTC_LICENSE=ANSYSnNUMBER_OF_PROCESSORS=16nOneDrive=C:\Users\David\OneDrivenOneDriveConsumer=C:\Users\David\OneDrivenOS=Windows_NTnPath=C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;C:\Users\David\AppData\Local\Microsoft\WindowsApps;nPATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSCnPROCESSOR_ARCHITECTURE=AMD64nPROCESSOR_IDENTIFIER=AMD64 Family 23 Model 113 Stepping 0, AuthenticAMDnPROCESSOR_LEVEL=23nPROCESSOR_REVISION=7100nProgramData=C:\ProgramDatanProgramFiles=C:\Program FilesnProgramFiles(x86)=C:\Program Files (x86)nProgramW6432=C:\Program FilesnPROMPT=$P$GnPSModulePath=C:\Program Files\WindowsPowerShell\Modules;C:\Windows\system32\WindowsPowerShell\v1.0\ModulesnPUBLIC=C:\Users\PublicnP_SCHEMA=C:\Program Files\ANSYS Inc\ANSYS Student\v211\AISOL\CADIntegration\Parasolid\PSchemanSESSIONNAME=ConsolenSystemDrive=C:nSystemRoot=C:\WindowsnTEMP=C:\Users\David\AppData\Local\TempnTMP=C:\Users\David\AppData\Local\TempnUSERDOMAIN=GAMING-RIGnUSERDOMAIN_ROAMINGPROFILE=GAMING-RIGnUSERNAME=DavidnUSERPROFILE=C:\Users\Davidnwindir=C:\Windowsnn -
February 10, 2021 at 9:21 pm
ANSYS_MMadore
Forum ModeratorPlease try setting the variable ANSYS_SYSDIR with a value of winx64.n -
February 10, 2021 at 9:48 pm
dslondon1
Subscriberno luck. Tried again downloading setup to program files x64 and running setup.exe as admin. No successn -
February 10, 2021 at 9:57 pm
February 11, 2021 at 2:16 pm
ANSYS_MMadore
Forum ModeratorIn your Windows environment variables, create a new variable named ANSYS_SYSDIR with a value of winx64. You shouldn't be adding it to any files or anything else. What file is that that you show in your screenshot, you shouldn't be editing any of the ANSYS files.n -
February 11, 2021 at 2:17 pm
ANSYS_MMadore
Forum ModeratorAlso, what application or shortcut are you trying to launch when you are encountering the error that prompted this post?n
Viewing 7 reply threads
- The topic ‘Installation problem’ is closed to new replies.
1724
1387
1248
