Ansys Products
Ansys Products
Installation issues UI
    • marissa.gaylord
      When I download Ansys 18.1 everything installs but then I go to open workbench and everything is very small I can not read any of the tabs.  have tried re-installation. I have tried changing text size settings but nothing is working. Due to this I am unable to do any modeling on ansys because the task bar is not legible. I have attached an image of exactly what is going on. Any advice on how to fix this would be greatly appreciated.
      Thank you
    • pgl
      Goodness! That's an eye chart for sure! Can you confirm what monitor resolution you are using? Is this a 4K HD monitor?
      Do you get the same result if you lower the resolution of your monitor?
    • marissa.gaylord
      My resolution is 3840 x 2160 I have tried almost every resolution available and it hasn't made a difference. I also changed tried changing the size. Any suggestions?
    • pgl
      I'm jealous, I'm using 1920 x 1080 on each of two monitors. Others have noted scaling issues with ultra high resolution graphics cards. Let me look into this some more.
    • marissa.gaylord
      Okay Thank  you so much for your help let me know if you need anymore information from me.
    • pgl
      Unfortunately we do not support UHD and 4K resolution displays.  A workaround that others report as working fine is to reduce the resolution (try 1920 x 1080) and then also adjust your windows scaling settings. Reboot after making the resolution changes. Also try on the ANSYS Workbench shortcut and select Properties. Under Compatibility select "Disable display scaling on high DPI settings".  Here's what my Properties dialog box looks like:
    • marissa.gaylord
      I fixed it!! Thank you so much for your help!
    • mtominsky
      How did you fix the issue?
    • pgl
      Excellent that you fixed the issue :-)  What was the magic tweak that finally sorted this for you?
    • marissa.gaylord
      Hey Guys Sorry for the delayed response on this. Below is an image of how I solved this issue. I right clicked on the Ansys workbench, then under compatibility tab. I selected "Override high DPI scaling behavior. Scaling performed by Application." Then select apply and reopen Ansys. You may need to restart computer to have your select applied but I did not have to restart.  I hope this helps others that are having similar issues.
    • pgl
      Perfect. Thanks for sharing that this worked.
    • Temmo
      Hi
      I had the same problem for the workbench. I fixed the problem for the workbench initial page but once i open the geometry it's all too small.
      can you help me?
    • acanuto
      I am having the same issue too.  I checked the override high DPI scaling and that fixed the small text issue at the main menu of workbench but when i open geometry or mechanical, the text appears small and it is overlapping each other.
    • user deleted
      Yeah ive the same Problem as described by acanuto.
    • AnirudhMS
      Even I had the same issue. It was probably a stroke of luck, when I was just playing with the settings that I could probably have solved the issue. I did the same thing as shown by marissa above. Properties of workbench > Compatibility > Click on Override high DPI scaling behavior. But then I changed the "Scaling performed by" option to "System(Enhanced)" instead of application. Now my Designmodeler works properly so does workbench. Hope it works for you too.
      Best.
    • Hemen Mohammad
      I had the same problem as [ Marissa. gaylord] with my newly downloaded ANSYS 19 as well as my Autodesk Robot and Revit. I did what pgl mentioned from the properties. Also, I lowered the resolution from  3840-2160 to 1920-1080.
      Not only solved the ANSYS resolution problem but the other two software as well. So thank you, Marissa, for sharing and thank you so much pgl for the suggestion.
      very grateful
    • ls5000
      I am having the same issue as well as acanuto.  I changed the DPI settings on Workbench but when I tried to do the same on Mechanical apdl I could not get it fixed.  Does anyone know the proper settings to fix this?
    • david1392
      SPAM
    • tsiriaks
      Try changing your screen resolution to not exceed 1920x1200 . If this still doesn't help, unfortunately, you will have to find a lower resolution monitor that has a native display resolution not exceeding the above number.
    • JustinGoKnights
      How Ansys Should Look
      If you notice that Marissa.gaylord posted a pic claiming that she fixed it. if you look closely you can see she did not. Her project tab save icon, and the others are very small and "project" is cut off. Later in the thread, Acanuto posted a pic of the Design Modeler with all the buttons squished. And the last "sorta" fix was from Hemen Mohammad, by changing the resolution of his screen. These fixes were unacceptable to me so I solved it good and proper(ish).
      How Ansys Should Look 2
      What I did was open C:Program FilesANSYS IncANSYS Studentv194... from here I went through a few directories
      ...v194ansysbinwinx64
      ...v194ANSYSViewer
      and there may have been a few others. But, I am not getting paid for this fix, it just annoyed me when tsiraks essentially posted get a new monitor. Using the Idea from AnirudhMS along side Marissa.Gaylord's "fix" I found every "Application" installed by Ansys did the same fix on each of them.
      Properties of "Application" > Compatibility > Click on Override high DPI scaling behavior, "Scaling performed by" option set to "System(Enhanced)" and now I have the results you see and my resolution is not degraded.
      My screen resolution is set to 2736 x 1824. It would be great if Ansys would figure out exactly which Application needs the adjustment. But, it only took 30 min to do the entire directory. I did not do them one at a time since a restart IS Necessary for the changes to take effect.
      Good Luck,
      GO KNIGHTS!
    • tocnaza
      Excellent. Thanks for sharing that this worked.
      catering - interioristas - chat
    • mynameismyrtle
       I am not sure that this worked. How?
    • ersch
      Hi all,
      I have partly managed to do the same as @JustinGoKnights, however it seems that my Model View in my Design Modeller has not adjusted to the settings(yet the Print Preview has), as seen in the picture attached. Drawing on where the Model View is supposed to be show tells me that it works where it is supposed to work, however the display is off(and not in the Model View how it should be.)
      I have done the following steps "Properties of "Application" > Compatibility > Click on Override high DPI scaling behavior, "Scaling performed by" option set to "System(Enhanced)"", as suggested above, to all the Ansys applications that I was able to find and change.
      I'm thinking that it must be one of the applications that I didn't find(one that displays the Graphics haha). Any idea where I can find this application, or how to solve this issue?
      Kind regards
    • yaskivi
      SPAM removed
    • PeterC
      I did the compatibility override trick on 2019v3, and it has mostly worked, but I'm not sure what application to use for DesignModeler and the Fluent meshing application. Does anyone know what they did that helped?.Never mind, I fixed it. Here's a useful trick if you don't know where to find a particular application:nRight click the application in the task bar, then right click the application name at the top, and change the properties there. This gives the same toolbar to change the settings without having to find the program file.nn
    • labyrinth01
      Hey, I am using Mac-pro Windows OS. I fixed this problem by changing properties of RunWB2.exe. Please have a look a the picture below.n
