September 27, 2023 at 6:07 pm
Aidan Hanratty
SubscriberHi,
I have tried to install the Ansys Student Software on my home PC, I have the correct specifications and space. I have downloaded the zip file, extracted it and then upon trying to open it i get the following errors
I was wondering if anyone could help me in trying to rectify this issue as I am trying to start my thesis. Thank you for your time.
Aidan.
October 3, 2023 at 3:51 pm
George Karnos
Ansys EmployeeCan you check the size of the downloaded file?
Also, when you ran setup.exe, did you right-click on it and choose "run as administrator"Do you have a virus scanner that could have blocked dll installation or access?
October 3, 2023 at 7:09 pm
Aidan Hanratty
SubscriberThe file is almost 13,500,000KB
I did right click and choose "run as administrator"
I do have an anti virus which is Norton I will try and look to see if that is the problem
Thank you very much for your help
October 7, 2023 at 10:03 am
Aidan Hanratty
SubscriberJust a quick update I made sure to stop my antivirus interfering with the download and I am still getting the same error, is there anything else that I can do to rectify this?
October 14, 2023 at 7:55 am
flaviosalvatore.cantalicio
SubscriberHi,
I just installed Ansys Student and am currently experiencing the same issue. May I ask if you managed to solve it? And if so, how did you do it?
Best regards, Flavio Salvatore.
October 14, 2023 at 10:29 am
Aidan Hanratty
SubscriberI went back deleted all files in the various places that they were saved in both where added the zip folder and on the C drive. Then I retried it but I also downoaded the links given on this chat
/forum/forums/topic/unable-to-load-dll-error/
It seemed to fully install then and I am not too sure which one it was that made it work but try both and hopefully you will get it.
- The topic ‘Installation issues’ is closed to new replies.
5969
1307
