August 3, 2025 at 10:02 pm
poulson
SubscriberHi, I seem to have a problem with the install, and hoping the forum can help me get past it. As a note, I installed a different package (ANSYSACADEMICSTUDENT_2024R2.2WINX64) and had no issues. So I am wondering what is the problem?
This is the Install.err file for ELECTRONICSSTUDENT_2025R2_WINX64.
Ansys installation: Sun Aug 03 14:19:32 2025
Revision: 2025 R2###### Error #######
Error executing custom python script configuration for 'C:\Program Files\ANSYS Inc\ANSYS 2025 R2\v252\installer\dev_configs\electronicsstudent\EM_config.py'
'C:\Program Files\ANSYS Inc\ANSYS 2025 R2\v252\commonfiles\CPython\3_10\winx64\Release\python\python.exe' terminated after 1 attempts with the following error(s):
Process crashed
Exit Code: -1073741795
August 4, 2025 at 6:06 pm
poulson
SubscriberMore details, it looks like the EM_config.py has some undefined enviroment variabler in the os import. This is from executing the python script after the install.
(Program executes to line 264)
Configuring Electromagnetics Suite…
Warning: C:\Promgam Files\ANSYS Inc\v\AnsysEM\product.info doesn’t exist
Traceback (most recent call last):
File “C:\Program Files\ANSYS Inc\ANSYS 2025 R2\v252\installer\dev_configs\electronicsstudent\EM_config.py”, line 339, in
configure_temp_dir (args.unconfig)
File “C:\Program Files\ANSYS Inc\ANSYS 2025 R2\v252\installer\dev_configs\electronicsstudent\EM_config.py”, line 117, in configure_temp_dir
with open(def_cfg, ‘r’) as file:FileNotFoundError: [Errno 2] No such file or directory: ‘C:\\Promgam Files\\ANSYS Inc\\v\\AnsysEM\\config\\default.cfg'
So I am gathereing, either the envirement isn’t being set or there is an error in the script,….
August 4, 2025 at 10:27 pm
poulson
SubscriberProblem solved. Need to manually set the ANSYS_INSTALL_DIR (ANSYS Student
) anad ANSYS_VERSION (252 <default>) in the system variables. Add the Install directory path, "C:\Program Files\ANSYS Inc\ANSYS Student <default>"
run,... python.exe EM_config.py from a cmd window with administrator privileges.
That is what worked for me, to complete the install and set the start menu links.
August 5, 2025 at 7:58 am
Ashish Khemka
Forum ModeratorThanks for the update!
Ashish Khemka
November 27, 2025 at 3:56 pm
alessandro.brugnoni01
SubscriberDear Poulson,
I’m experiencing the same issue. As you said I tried to change the EM_config.py file as follows:
{install_dir = "C:\\Program Files\\ANSYS Inc\\ANSYS Student"
version_dir = "252"
year_version = "20" + version_dir [0:2] + "." + version_dir [2]
install_base = install_dir + "\\v" + version_dir + "\\AnsysEM"
}Then, I ran the cmd.exe as administrator and typed:
cd C:\Program Files\ANSYS Inc\ANSYS Student\v252\installer\dev_configs\electronicsstudent
This appears:
Warning: \v\AnsysEM\product.info doesn’t exist
File “C:\Program Files\ANSYS Inc\ANSYS Student\v252\installer\dev_configs\electronicsstudent\EM_config.py”, line 339, in
File “C:\Program Files\ANSYS Inc\ANSYS Student\v252\installer\dev_configs\electronicsstudent\EM_config.py”, line 117, in configure_temp_dir
OSError: [Errno 22] Invalid argument: ‘\\v\\AnsysEM\\config\\default.cfg'
Could you help with this issue, please?
Thank you in advance.
5654
1885
1404
1303
