February 24, 2021 at 10:55 pm
pedroaum
SubscriberHi, the installation presented the following problem:
SC Workbench PlugIn ..... Not Configured
I'm attaching the log files.
I tried to install it multiple times, without success.
Could you give me some direction?
Thank you in advance.
Rgds
Pedro Aum
February 26, 2021 at 5:47 pmGeorge Karnos
Ansys EmployeeHello Pedro,
Did you extract the zip file to a temporary directory?
When running Setup.exe, did you right click and choose more->run as administrator?
If not, please do so.
Best,
Geo
February 27, 2021 at 10:54 pmpedroaum
SubscriberThank you for your answer Karnos.
yes, I extract the files.
Yes, I ran the setup choosing "as administrator".
All installation looks concluded with exception of the workbench that doesn't appear installed. So I cannot open the workbench.
"SC Workbench PlugIn ..... Not Configured"
April 7, 2022 at 1:13 pmCHOUI
Subscriber.Conditions préalables ..... Configuration réussie
SC Workbench PlugIn ..... Configuration réussie
Discovery Workbench Plugin ..... Non configuré
Les associations de fichiers ont été effectuées.
Installation achevée, avec avertissements/erreurs. Examiner tous fichiers .err ou .log dans :
D:ANSYS IncANSYS Student
.April 7, 2022 at 4:22 pmRob
Forum Moderator.Can you try installing on C: There have been a few problems installing elsewhere with the Student version.
.May 13, 2022 at 2:40 amJFTG
Subscriber.I´m having the same issue as Pedroaum when trying to import a geometry from Inventor, it says "Discovery Workbench Plugin ..... Not Configured
What can I do in this case?
Thank you.
.May 13, 2022 at 8:44 amRob
Forum Moderator.JFTG with Student, or a University build of the software?
.November 4, 2022 at 11:47 amNikhil Sai Kurakula
SubscriberHi,
Could you resolve this problem which is occuring while installing
Problem : - " Discovery Workbench PlugIn...... Not Configured"
November 18, 2022 at 12:37 am
Yingwen Weng
SubscriberHi, I also face the problem "Discovery Workbench Plugin ..... Not Configured". Do you know how to fix it?
July 5, 2023 at 6:29 amroy.ramadhin
SubscriberHi, Is this issue solved? I have tried several times to install Ansys V212, but get the same error SC Workbench .... Not Configured. And cannot import .scdoc files in workbench.
Viewing 8 reply threads- The topic ‘Installation error: SC Workbench PlugIn ….. Not Configured’ is closed to new replies.
