May 7, 2024 at 10:41 pm
May 8, 2024 at 11:04 am
Rajeshwari Jadhav
Forum ModeratorHi Michael,
Please attach the screenshot of the error again, it did not load.
May 8, 2024 at 12:53 pm
May 8, 2024 at 1:00 pm
Rajeshwari Jadhav
It looks like the default TCP port 8080 is probably being blocked somehow on your network. If the you are able to identify a port number that is not reserved by any other application running on your network, you can direct the installer to use that port number for logging in. For example, if you have TCP port 50000 open on your network, yoy could use the following command line to login by communicating over that port(If needed, get help from your IT.):
"AnsysInstaller.exe" -login_port 50000
May I know from AnsysInstaller which package would you be using? If it's only 1 single package then you can download packages from primary packages section.Â
May 8, 2024 at 1:14 pm
weinerm
SubscriberBlocking a localhost port is not something we do, so that is a little confusing. As for the package, i believe all i need is Fluid.
May 8, 2024 at 1:46 pm
- The topic ‘Installation 404’ is closed to new replies.
5824
