Inserting commands into geometry
    • Chamini
      Hi All,
      I want to simulate tensile/compression loading of a part using Ansys static structural. For that, I need t oinput customized stress-strain data obtained from the experiments into the geometry part. I tried to insert it as a command (APDL) but could not open the command window. Why it is happening like this?
      Can you recommend me any other methods for inserting stress-strain data?
      Thank you
    • Wenlong
      Hi Chamini,
      What is the purpose of inserting stress-strain data into a command snippet? If it is to define a material property, it should be handled in "Engineering Data“. Please check this relevant post: /forum/forums/topic/compression-test-on-specimen/
      Wenlong
    • Chamini
      Hi Wenlong,
      Thank you for the information.
      I am still new to theses simulations and I came across this while practicing a video tutorial. What I'm concerned gere is that my software is not functioning well where it get stucked or opens up blank. Screenshots of some issues I faced are attached below.
    • Aniket
      As a workaround,try using the import and export features from the toolbar (can also be accessed from the context menu by right-clicking on the command snippet) and check if it helps.
      -Aniket
      How to show full resolution image
      How to use Google to search within Ansys Student Community
    • Aniket
      Also, try the following workarounds.
      1. Restart Mechanical
      2. Reset window layout
Viewing 4 reply threads
  • The topic ‘Inserting commands into geometry’ is closed to new replies.
