July 29, 2024 at 11:10 pm
Noura Mansour
Subscriber -
July 30, 2024 at 3:55 pm
Mike Rife
Ansys EmployeeHi
You can change the 'Longitudinal Stiffness' of a Spring to 'Tabular Data' then enter the force-deflection data points in the table that appears. After inserting a Spring in WB Mechanical.
Mike
July 30, 2024 at 11:13 pm
Noura Mansour
SubscriberHow can i make this if inserted the spring geomtry from SOLIDWORKS ?
July 30, 2024 at 11:27 pm
Mike Rife
Ansys EmployeeOh ok, that is a different problem altogether. So you have a 3D model of a spring? The stiffness will be a function of the geometry and the material. Do you need a 3D model of the spring? Or just a 2 node line element representation of the spring that has a force-displacement function that matches what you are showing in the plot?
July 30, 2024 at 11:28 pm
Noura Mansour
Subscriber3D modelÂ
July 31, 2024 at 2:17 am
Mike Rife
Ansys EmployeeSo not really a boundary condition, more of a 3D modeling and material property issue then, right?
July 31, 2024 at 2:34 am
Noura Mansour
SubscriberSorry I can't understand you what do you mean ?
July 31, 2024 at 3:03 am
Mike Rife
Ansys EmployeeI mean if you want a 3D model of a spring, which has a specific force-deflection curve, then the 3D geometry plus the material (and possibly other factors like contact) determine the force deflection of the system. Â
July 31, 2024 at 3:06 am
Noura Mansour
SubscriberYes i understood but i want to ask about how i insert a load at zero deformation like the curveÂ
- The topic ‘Inserting a load at zero deformation’ is closed to new replies.
5574
1885
1403
1298
